cars4life
An artists impression of the next gen Honda Brio
Brilliant....No words mistaken....Absolutely Spell Bound.......
though I doubt the original / actual output will be this bcoz this is nothing bt Honda VEZEL with lower Grund clearance and maybe with toned down interiors and detuned 1.2 L I-VTEC. but exterior is absolutely similar to Vezel aka CR-U in the international market. If Honda launches Vezel in India , No chance brio can look even like this as Brio will always play Second fiddle to JAZZ. if vezel is not launched , then maybe , just maybe some cues are taken from Vezel , ...
Last but not least , I will be very happy to be proven wrong....
Looks like the second-generation Honda Brio is all-set to be revealed at the GIIAS 2018 this week in Jakarta. It will carry styling similar to the Honda Small RS concept that was shown at the Indonesia International Motor Show earlier this year, but racy bits on the concept like faux diffusers and the body kit will not make it to the production car.
Found a rendering showing what the all new Brio could look like:Capture.PNG
And here's the Small RS concept:
For more information, you can head here: https://goo.gl/ULjPhq
Source
Honda's finally revealed the second-gen Brio at the 2018 GIIAS. It gets similar styling to the Small RS concept. here’s also a clear link to the first-gen Brio, right up to the B-pillar. However, the rear door appears to be much larger along with a longer rear overhang. At the back, the new Brio also has a full tailgate, which is a departure from the glass hatch seen on the first-gen car.
The interiors of the new Brio seem to be shared with the recently updated Jazz for India. However, the RS variant gets a 6.1-inch touchsreen infotainment system (there's a 2-DIN audio system on the standard one) and highlights on the dashboard and around the AC vents.
For the Indonesian market, the 1.2-litre petrol engine that makes 90hp and 110Nm of peak torque, along with the optional CVT automatic, continue unchanged.
For more info you can head here: http://www.autocarindia.com/car-news/all-new-2019-honda-brio-revealed-409240
Found a good walkaround that gives an up-close look at the car:
