abugeorge07
Accelerator Pedal Vibrations
Only the service guys at fiat can assist you even if you know the cause of the problem. The problem may be with the spring which keeps the clutch plates separated. I think the vibrations doesn't take place when your car's gear is in neutral or when clutch pedal is fully pressed!
Actually accelerator pedal has nothing to do with vibrations as operates a wire.
