cars4life
Pics: Next gen Nissan Sunny
Rendering artist Theophilus Chin has come up with this rendering of what the next gen Nissan Sunny could look like. He has used the new gen Micra as a base and worked a boot on it . The end result is quite nice and def looks better than the current Sunny which looks a bit weird at the rear. If the new Sunny is close to this rendering, Nissan has a winner on its hands for sure.
Source
This rendering is the exact same design of the Mazda 3 sedan currently being sold in the U.S.Market, swapped with a Nissan Altima front and rear which is also sold in the U.S.
I'm pretty sure Sunny won't look like this.
It can look like Nissan Sentra: https://www.google.com/search?q=2016+nissan+sentra&safe=off&espv=2&biw=1229&bih=607&tbm=isch&imgil=p5S9ayF_CHYy9M%3A%3BDQ5JeOCmt3kSqM%3Bhttp%253A%252F%252Fwww.nissanusa.com%252Fcars%252Fsentra&source=iu&pf=m&fir=p5S9ayF_CHYy9M%3A%2CDQ5JeOCmt3kSqM%2C_&usg=__rRjPXAgkx37GutHVdsJyf-DMeqU%3D&ved=0ahUKEwjc2eezyNvQAhVX5WMKHfjFCDkQyjcIoQE&ei=x5VEWJzaONfKjwP4i6PIAw#imgrc=p5S9ayF_CHYy9M%3A
Here it is! The next-gen Sunny has been revealed. It's based on Nissan's updated V platform that also underpins the international-spec Kicks SUV. Up front, it is fitted with Nissan’s signature V-shaped front grille with thinner and more angular headlights in comparison to the outgoing car. It also gets a new design for the alloy wheels, a larger rear door and a floating roof design as seen on the Kicks.
The cabin is almost identical to that of the Kicks. Nissan will launch the Sunny in international markets with the 124hp, 1.6-litre petrol engine that does duty in the international-spec Kicks. Transmission options will include a 5-speed manual and a CVT automatic gearbox.
You can find more info here: https://www.autocarindia.com/car-news/next-gen-nissan-sunny-revealed-412335
1_578_872_0_70_http___cdni.autocarindia.com_ExtraImages_20190415010821_Nissan-Sunny-Versa-front.jpg
1_578_872_0_70_http___cdni.autocarindia.com_ExtraImages_20190415010821_Nissan-Sunny-Versa-rear.jpg
1_578_872_0_70_http___cdni.autocarindia.com_ExtraImages_20190415010825_Nissan-Sunny-Versa-side.jpg
1_578_872_0_70_http___cdni.autocarindia.com_ExtraImages_20190415010827_Nissan-Sunny-Versa-interior.jpg
1_578_872_0_70_http___cdni.autocarindia.com_Galleries_20190415124534_Nissan-Sunny-Versa--front.jpg
Finally came across a good walkaround giving a closer look at the new Sunny (Versa). What do you think of the styling?
