The engine is a component that converts the energy from the fuel into the mechanical force used for riding a bike. Even if your bike has all other parts from the top-notch manufacturer, if the engine is not maintained well, then it's going to ruin your riding quality. With such a significant number of motor oils for a bike accessible in the market, it is a moving activity to pick the best bike oil for the bike.
But at first, you should know that for bike there is always one grade recommended that is 10w30, 10w40, 10w50 and the second specification is apisj, apisl, apism, apisn. The api grade is for engine performance as well as its requirement.
Honda Hornet 160r contains a high rev performance engine, and most of the manufacturers are nowadays recommending for energy conserving oils. These oils have low friction and more cooling abilities. The engine oils with high viscosity are not much energy conserving.
The recommended grade for Honda Hornet 160r is 10w30, and you can use 10w40, 10w50, 5w30, etc. but you cannot put 20w50, 15w40 in this bike.
The engine oil quantity is also different depending on the size of the engine and the bike design. Based on all these factors, you have to choose the best bike engine oil. There are different types of bike oil offered by Gandhar oil. You can select from them according to your requirements.
