nbmotosport
FZ 150 launch in mid september!
Yamaha told visitors at its expo stand when I was there that this bike will launch in October. I even overheard someone from the company talk at that time a precise engine size figure of 156cc.
Lets wait and watch. This is surely one of the best looking bikes ever to have come to India. Lets pray we can afford to buy it and Yamaha keep the price within reach of the masses.
It will be launched in Sep itself, but will probably be available by October only. And it will be a 150cc only i think. Price should be in the late 60s to early 70s. Anything higher and Yamaha might blow it!
What I heard is launching is on 18 sept.but yamaha should see that price should not be very high ,because people hesitate in buying new bike ,and if price is high they will become reluctant ,and wait for the performance on road due to which sales decreases and if mileage is also low then spending  too much money, as running cost also increases with initial cost, is difficult
i heard the bike lauch is on sunday in GOA' date=' yeah.[/quote']
Hello! I am in Goa, no new on the FZ here yet.
it is smiley1.gif. finally its here, i dont know what the other manuf are up to
Yamaha FZ 16 Specifications
  • Engine: 153.7 CC four-stroke, air-cooled, single-cylinder, 2 valves, SOHC
  • Power: 15PS @ 8,400 RPM (Estimated)
  • Gearbox: 5-speed
  • Fuel System: 26mm CV Carb
  • Wheels (F/R): 5-spoke 17? die-cast alloys
  • Tyres(F/R): 100/60-R17, 140-60-R17
  • Brakes(F/R): 267mm single cross-drilled ventilated rotor with 2-pot calipers / 130mm drum
  • Suspension: Front: 41mm Telescopic Forks - Rear: Monocross type
  • Headlight: 12V 35W Halogen with Multifocal Reflector
  • Exhaust System: Mid Ship type, side mounted
  • Tank capacity : 13 litres
Type: Naked
Top Speed: 132kph
Fuel Consumption:
City
36.00
Fuel Consumption:
Highway
47.00
ENGINE SPECIFICATIONS
Displacement: 153cc
Engine: Air-cooled, 4-stroke, SOHC
Maximum Power: 14bhp@7500rpm
Maximum Torque: 13.6Nm@6000rpm
Gears: 5 Manual
Clutch: Constant Wet Multi Plate
Bore: 58
Stroke: 57.9
No. of Cylinders: 1
Valve Per Cylinder: 4
Chassis Type: Diamond
Cooling Type: Air Cooling
DIMENSIONS
Length: 1975.00 mm
Width: 770.00 mm
Height: 1045.00 mm
OTHER SPECIFICATIONS
Weight: 126.00 kg
Ground Clearance: 160.00 mm
Fuel Tank: 12.00 ltrs
Wheelbase: 1335.00 mm
Headlamp: 12V35W / 35W?{35W
Wheel Type: 5 Spoke Alloys
Wheel Size: 100/60 - 140/60 mm
Tubeless: check.gif
Colors: Lava Red, Midnight Black and Flaming Orange
ACTIVE AND PASSIVE SAFETY
Suspension(Front): Telescopic
Suspension(Rear): Monocross
Brakes: 267mm Hydraulic Disc
Brakes(Rear): Drum
Stand Alarm: check.gif
