JustStarted
i10 alignment problem
I have 2008 i10 1.2 magna running on stock tires, its steering wheel is harder than before from last 15 days, earlier after taking turn it just came back to center position without any touch but now it doesn't.
I thought its alignment issue and went for alignment and balancing (all four wheels) yesterday but even after alignment and balancing done issue is there. steering is not light as before, so should i take it back to alignment shop again or check with Hyundai Service Center.
I think it cant be repaired by the alignment guys. Do get it checked again, the Indian i10 comes with 155/80 x 13 tires which actually have a larger diameter and therefore circumference. You can check if there any play in your ball joint by jacking up the front and moving the wheel from side to side.
