MMP09
engine coolant brands
Hi..
Can someone suggest good brands for engine coolant and where can one buy them? Do they come as pre mixed solutions?
Current level of coolant in reservoir tank is ok, approx 1 / 5 th above low mark, however plan to top it up more. Any inputs are much appreciated.
Just to give you an idea ,Almost every engine oil manufacturing brand has a coolant offering so you will find coolants from Castrol,Servo , Mobil and the likes
Less all of them are available in concentrated form , the dilited ones you only find at free car check up camps :-D
Make sure you dilute is as per instructions or else just using the concentrated product will cause corrosion.
