sidsafari
worthy replacement required for stock headlights for maruti SX4.
sid
Your car can only house H4 bulbs, which have H/L beam integrated into one bulb. Generally cars with twin barrel headlamp setup have h7 setups with two different bulbs.
If you are looking to improve light then both nightbreakers and extreme vision are good options. They are available in h4 options.
There are some very good projector setup for sx4, which you can import from outside. They will be costly though.
I'm using Halonix 130/90w bulbs with relay on my Esteem for the last 1.5 years and no problems so far. The total cost was 130 for the bulbs and 750 for the relay. The total cost including installation came to Rs. 1000. There is no blackening or melting of reflectors despite some long night drives. You can also consider this option but also be considerate for others on the road. Using high beam with upgraded bulbs can cause problems to oncoming vehicles.
As they say, there is no replacement for displacement. Try 90/100 ones, they don't cost more than 200 rupees a pop and really change the way the world looks in the front at night. Get a relay kit along with it which is a direct plug and play.
100/130 will blacken the headlight reflectors in the long run due to the intense heat they produce.
@livetodrive All marutis have metal reflectors. So you need not worry about its blackening or melting. It all depends on the user's choice whether to go for high powered bulbs or for 90/100 ones.
