Champak 2 Report post Posted November 2, 2013 Hello. I have a Hyundai Santro Xing and it doesn't get used much - it has 50,000 km on the odometre. Between every 6 monthly service, I do around 2000 to 2500 km. For the last two services, I received a whopping amount on my invoices. The following items were common in the invoices. Do all of these need to be done so frequently? What will happen to my car if I stop them from doing all these? Also, is it necessary for me to get my car serviced every six months given that it doesn't get used that much? Items on invoices Wheel balancing Wheel alignment Throttle body cleaning Fuel injector cleaning Engine oil Battery water Wheel weight Filter Assy - Engine oil Brake shoe cleaning Caliper pin greasing Engine flushing Super charge O-ring Engine decarbonizer: they insist on this with every scheduled service Differential and trans treatment Gasket oil plug Plug-oil drain Any help to understand this will be appreciated. Thanks in advance. 1 Exextunse reacted to this Share this post Link to post Share on other sites
Prashantroxx 5 Report post Posted November 2, 2013 Your car is doing some Km amd so it think so u should get it serviced. For santro i think so it is recommended at 5000km or 6 moths and you do have the distance. You should service your car or if any problem comes, the workshop can accuse the non-regular servicing Share this post Link to post Share on other sites
rssh 59 Report post Posted November 2, 2013 Don't do engine decarb no car needs it and it is not manufacture recommended. Engine decarb is needed if the car barely passes the PUC or once in 1 lakhs kms, its a rip off technique by after Sales . Also engine flush is not required unless the engine oil wasnt changed since long time and was very dirty and thick. Get the transmission fluid changed and change the rear brake pads because often people tend not to change them saying that the rear brakes are hardly used (I keep a rule change the rear along with the front every alternate change of brake pads). Yes get the brake serviced it might have some rust. Throttle body cleaning and fuel injector cleaning is alright for a 50k km service. Get you headlamp alignment and do the wheel balancing and alignment aftermarket because they are cheap and better than A.S.S. Also ask them to check the timing belt for wear and hardness due to age. Check the suspension bushes and replaced them if there are some cracks on the rubber it will help you ride and last the suspension longer. Share this post Link to post Share on other sites
sushant walki 0 Report post Posted November 4, 2013 You don't need a engine decarbonizer. Even you do not need a oil flush if you change the oil regularly. Differential and transmission treatment there is nothing like this in the maintenance and as you drive a Santro Xing it does not have a differential. So just check out with the guy you serviced your car. Throttle body and fuel injection system is to be cleaned after every 50k km for the smooth running of your engine. Share this post Link to post Share on other sites
harikkuttan 1 Report post Posted May 1, 2014 can any one tell me a good wheel aligment garage near Colaba, Navimumbai or Chembur in Mumbai Share this post Link to post Share on other sites
LeoRahi 31 Report post Posted May 1, 2014 can any one tell me a good wheel aligment garage near Colaba, Navimumbai or Chembur in Mumbai Gateway Auto Services Behind Regal Cinema, Shivaji Maharaja Marg, Colaba, Mumbai - 400005 Ph. No. - 9321577774 Share this post Link to post Share on other sites
harikkuttan 1 Report post Posted May 2, 2014 Thank you LeoRahi. I just contacted the guy . the moblie number is correct. I want to go for a tyre replamenet also. What is the best tyre opted, for a little heavy hatch backs like Fiat Punto. Appolo, Goodyear or Bridgestone. Are there any grades/codes for durability, performance, etc if any Share this post Link to post Share on other sites
LeoRahi 31 Report post Posted May 2, 2014 Welcome Harikuttan. Regarding the tyres I have very little knowledge, you can check this thread for your query Share this post Link to post Share on other sites
