sidhu51 0 Report post Posted May 9, 2014 Can my Manual Steering Maruti Zen LX 2002 model converted to a Power Steering. Also i want to find some verygood company in chennai which does the converison. Quote Share this post Link to post Share on other sites
Hitlerinlove 0 Report post Posted May 11, 2014 The maruti suzuki zen came with a electronic power steering orignally fitted by manufacturer. There was an issue with the electronic steerings in zen which failed at some stage in many cars due to water getting in the circuit due to washing as owners were unaware or at other times that circuit failed . But that small circuit , the size resembling the bigger homelight matchbox , also failed at other times out of unknown reasons. The electronic power steering mainly composed of that circuit control i mentioned above which costs around from Rs 3500 to Rs 5000 depending upon its repaired or orignal , available with disposal shops and the motor around Rs 8000 in the disposal market. Its good if you could find a company that does the job OR the otherway is if you could source one from disposal market complete set . I guess it should cost you below Rs 15000 and your mechanic should be able to install it with the help of electrician. Quote Share this post Link to post Share on other sites
rssh 59 Report post Posted May 11, 2014 I think it would be better to sell your car and buy one which has power steering. Maruti will charge 18k for conversion and usually the second hand/ aftermarket ones can't be trusted for reliability. Quote Share this post Link to post Share on other sites
PrancingHorse 1 Report post Posted May 12, 2014 Well it is a possibility but you have to find a power steering specialist who can do the job. I have a friend who got power steering fitted onto his 10 year old Qualis and it works like a charm. As long as the person who does the conversion knows his job, it should work Quote Share this post Link to post Share on other sites
