diwakar11
Monsoon car accessories
During monsoon your car needs as much care as you take of yourself. You are left
with two options either you completely covered your car to keep away from monsoon
or you have to protect it from this. It is worthwhile checking all the essentials in the car before monsoon god letting out his love on us.
New wiper blades, all the indicator lamps in working condition and headlight are clear for maximum light on road. Air conditioning in proper working condition to clear the condensation from the glasses during the rain season. Hand brake operational.
Also check the tires, make sure they have enough tread left, avoid accumulation of dirt under the vehicle.
Ensure the vehicle is serviced properly, before going on long trips in Monsoon.
^^ Adding to this :
1. Maintain tyre pressure, Check if worn out. Change it ASAP
2. Doing a underbody treatment is a good way of getting rid of underbody dirt which is worse/worst in monsoon.
I think replacing all the wipers and checking all the electricals is a must also cleaning all the drums and break pads can help a alot in breaking. If you have highways driving there are chances that oil contens can also be spliied on your glass along with the water which leave rainbow stains on the front glass to avoid this we can add a shampoo sachet along with water in your so that when ever you
shower water
the detergent can remove these oil stains
@kuntal I agree with you using a good quality car shampoo is so important than that regular hair shampoos because it is harmful for the body color of car and also its cleaning results are narrow in front of branded car shampoos.
