goenkakushal
ALTIS Brake pads an Disc
Dear all,
I have given my vehicle for 60 k service . Service advisor has reported that the Brake bads and Brake Discs are worn out.
Brake disc thickness is 22 mm which is very less according to him.
I am aware the Brake pads actually do need replacement but total cost for Brake pads and Brake Disc is comming close to 45k.
My vehicle is of 2009 i really dont want to spend almost 50k only on brakes.
Kindly advise what are after market options available in Mumbai
In Honda Amaze the thickness of the brake disc, when new is 21mm and replacement limit is 19mm. For brake pads thickness of brake lining when new 9mm and limit is 1.6mm. Spares of Corolla altis are costly.
