KKEAUTOCARE
How Waterless Car Wash Chemical works ?
The reason probably you are here is may be you are wondering "What this Water less Car Wash is?"
Water less Car Wash though a new commercial concept, but it has been here since almost 20 years.
KKE Dry Wash liquid needs to sprayed on the car in segments and then wiped off using a clean Microfiber Towel.
Use strokes in one direction only.
For each stroke, a clean area of the microfiber should touch your car surface. Allow the liquid on car to dry if the dirt has been removed, else spray KKE Dry Wash again and wipe off. Once dried, use a dry micro fiber cloth to buff off and make your car shine.
For a moderately dirty car, you would require at least about 4 - 6 towels.
Do not use household detergents to wash your Microfiber towels, they'll reduce the life of the towels and also the hard towels will scratch your paint surface.
Recommendation: KKE Linen Clean which is a fabric softener and cleaner
Instead of the chemicals I would prefer going for steam jet wash for my car. This saves water as well as cleans the car perfectly. I went to a car wash facility in Noida and heard about this. Loved the outcome. It didn't leave a trace of water.
Interested in knowing more, I checked on the product they were using and there was a name which when tracked was of a local manufacturer. Impressed by this manufacturer's product. I wanted to know more and found their website. You can also check them out and see for yourself if chemicals are better or this steam machine was good enough.
