Devendrasinh surve
2 Lakhs Kms Swift VDi
Last year i bought Swift VDI i am third owner Which had clocked 1,90,000 Km  next Month it will be clocking 2 Lakh Km. I did not change the Engine Oil as the 2nd owner had just changed it.  What are the works to be done for 2 Lakh Km.. My Swift is working very fine In city with Tank Full i Get 19.5 Km and Highway i get 21.5 Km..
My mechanic has listed following works
1) Engine & gear oil
2) New oil filter, diesel filter, air filter
3) Timing Chain.
4) New Water Pump & New Oil Pump
 Should i clean the EGR , should i Decarb the Engine
 Kindly tell me what works i should i do from my mechanic.
@Devendrasinh surve diesel car, you are lucky to get above fuel average. Ideally you should get the complete overhaul of the Turbo that is renewal of the bush bearings, thrust pads, seal rings, O-rings etc, cleaning of its turbine blades, volute casing & the nozzle ring. Also EGR mentioned by you. If intercooler is there then get it decarbonised too. Renew rubber reinforced hoses in and out of the intercooler. The list is not limited to what I have mentioned. The catalytic converter too, to be unclogged.?
Edited by vikky1971
More matter to add
