VET5
New Honda Passport SUV revealed
Here's the new five-seat Passport SUV. It will slot above the CR-V in Honda's US range.
The Passport gets a single engine-gearbox combination – a 3.5-litre V6 petrol engine making 284hp and 355Nm of peak torque that is mated to a 9-speed torque convertor automatic transmission. While drive is sent to the front wheels as standard, customers can also spec the SUV with Honda’s i-VTM4 all-wheel-drive system.
The cabin of the Honda Passport is claimed to be class leading due to its larger size and five-seat layout. In terms of features, it gets A 590-watt audio system with an 8.0-inch touchscreen (on the higher-spec models), which gets Android Auto and Apple CarPlay. Lower trims get a 215-watt audio system with a 5.0-inch display. You can find more info here: https://www.autocarindia.com/car-news/new-honda-passport-suv-revealed-410597
Here's an up-close look at the SUV:
