monir302
Car Wash
How you Wash your car
Washing your car by hand can be a relaxing and satisfying activity. Washing your own car will save you the money that would otherwise be spent paying for a car wash, and allows you to give extra attention to especially dirty areas of your vehicle. Commercial car washes use abrasive materials that may scratch or damage your car’s paint, so washing your own car by hand will allow you to keep the vehicle and paint job in pristine condition. To wash your own car by hand, you’ll need a flat, shady patch of concrete, and access to plenty of water and a hose. You’ll need to wash your entire car in one session, which usually takes an hour or two depending on the size of your vehicle and how dirty it is.
Followings are need To wash your car :
·        Shady work-area.
·        Car wash soap.
·        Hose.
·        2 large buckets.
·        2 Thick wash mitts or sponges.
·        Towels, cotton.
·        Vacuum cleaner.
·        Pledge or wax.
·       Scrubber.
1)   Preparing to wash the car:
Any one can effort the a new brand recently launch in market with low cost . https://www.carwale.com/mercedesbenz-cars/c-class/
a)    Park the car out of direct sunlight.
To prevent premature drying which can leave splotches on the paint. Washing your car in direct sunlight also runs the risk of your car becoming hot while you wash it, which will result in water evaporating more quickly and making the cleaning process more difficult. Please also closed the all windows to prevent water from getting inside the car. Pull the windshield wiper away from the glass. mercedesbenz
B)  Set everything you will need near the car.
This includes cleaning material: the car wash detergent that you will use for cleaning, a large supply of water (depending on the size of the vehicle), three buckets (two for washing, one for rinsing), a hose, and microfiber cloths or towels to dry your car.[2] You’ll also want to have two or three wash mitts on hand, plus a large sponge, a stiff scrubbing brush, and maybe a separate brush to scrub your tires with.
c)     Fill a bucket with water.
Then add car wash soap wash in the quantity directed in the bottle. This will be your washing bucket. If your can is very dirty or if you do like to have a washing bucket for the body of your car and a separate washing bucket for washing your car’s wheel wells, you can fill two buckets with water and soap.
d)    Fill another bucket with plain water.
 This will be your rinsing bucket. You only need one bucket for rinsing, whether     you have chosen to use one or two buckets for washing. mercedes benz,
2.    Washing the car
a) Hose off the car to loosen and soften the dirt. Don’t use a strong jet of water from the hose, as this can rub grit over the paint and scratch it. Try to aim the jet of water downwards on all surfaces.[5] Aiming upwards around windows may cause water to dribble into the car if there are flaws in the rubber seals.
B) Wash the wheels first. Since the wheels of your car are often the dirtiest part, it’s a good idea to wash them first, so that dirt rinsed off of the wheels won’t land on an already-clean part of your car.[6] Use a long, skinny wheel-brush for cleaning the openings of the wheels.
c) Wash your car using a large wash mitt. Before you begin scrubbing the surface of your car, soak a large wash mitt or sponge in the soapy water, being certain to wash out any dirt in it, and begin applying it to the car.[7] Do not use a brush on the car body, because this may leave little scratches. mercedes benz.
e)    Wash the car section by section, starting at the top. Circle around the car several times, washing lower areas with each round.[8] Washing the car from the top down will allow soap to drip over lower sections of the car while you’re still washing higher sections. This will prevent you from having to wash the same sections twice.
f)      Scrub off bird droppings or splattered bugs. Bird droppings and bugs can damage the paint, and extra care should be taken to remove them while washing the car. Get them off as soon as possible using a damp rag if you need more scrubbing power than the wash mitts can provide.[9] Soften bugs by dabbing with a sponge that is loaded with warm water, then let the water soak in and scrub the bug off.
g)    Keep the wash mitt clean. Rinse the dirt out of the wash mitt or sponge in the bucket with plain water frequently.[10] If you allow dirt, grime, and grit to build up in the wash mitt, you’ll risk scraping or damaging the car’s paint. Rinse the mitt regularly in the rinsing bucket and, when the water in the bucket has become opaque or gritty, throw it out and re-fill with clean water.
h)    Rinse each section after you’ve washed it. After one section is washed, rinse it with the hose before moving on.[11] You don’t want the soap to dry on the paint and stain it. When rinsing sections, follow the same top-to-bottom pattern that you’ve used to wash the sections of your car.
i)       Keep the entire car wet as you wash it. As you progress from one section to the next, it’s important that you use the hose to keep the entire car wet. This will prevent water droplets from drying on the paint and leaving water spots. You want to be able to dry the car with towels before it air dries.
j)       Save the lower body of the car for last. Scrub the lower body and the wheels last, as these are the dirtiest, grittiest parts.[12] It’s a good idea to use a separate wash mitt or sponge on the bottom, as you’ll likely end up with a completely soiled wash mitt from this part of the car alone.
k)     Clean the tire sidewalls with a plastic brush. If your tires are gritty or have absorbed dirt and grime from the roads you’ve driven on, you may not be able to successfully clean them using only a sponge or wash mitt.[13] Use a plastic brush with stiff bristles to clean the dirt from your tire sidewalls.
l)       Spray the hose over the bottom of your car. At some point after you’ve washed the majority of your car’s surfaces, use the spray from your hose to rinse the bottom of the car, from various angles.
3.   Drying and Waxing the Car
a)    Dry the vehicle with fresh towels. Don’t be afraid to use several towels while drying your vehicle—fully wipe down all surfaces that you’ve washed, in order to prevent rust from building up. Make sure not to leave any water standing on your vehicle once it’s dried, as this can tarnish the paint or cause rust.
B)    Wax the car once it’s been dried. Wax (or similar polish) should be applied to a clean, dry car. You may need to wax the vehicle more than once: the failure of water to stand up in beads (or the presence of small pools of water on the car’s surface) after washing is a sign to re-wax.[15] Abrasive polishes are rarely, if ever, needed with modern car paints and risk unexpected damage scouring through a clear coat.
c)     Treat rust and paint damage as needed. Remove rust from the car and touch up the paint if there is significant damage, or easily stabilize and seal small scrapes and rust spots with rust converter. Wash off any grit or corrosive pre-treatment chemicals, allow rust converter time to dry and cure, and do not wax a fresh paint finish.
d)    Apply a water-repellent treatment to the windows. Apply RainX or similar water-repellent treatment to clean, dry glass to repel water from it and improve visibility. Reapply the repellent when water no longer forms small beads. Do this every few months on side and back windows as may be desired, every month or so on the windshield, where it is most needed and from which the wipers will tend to rub it off.
Warnings:
·        Do not use Windex or any window cleaner containing ammonia on the inside of color tinted windows, as it will discolor the tint and cause it to peel. A better option is a tint-safe window cleaner.
·        Keep your pets and little kids inside the house when cleaning the car. Most chemicals can be toxic to pets and little kids. If they swallowed the cleaners, call a poison control center right away.
