VET5
Next-gen Toyota Harrier leaked
The fourth-gen Toyota Harrier has been leaked online... looks like it now gets a larger lower grille, LED daytime running lights, and the rear sports some major changes as well! What do you think of it?
Source
For those who want a closer look at the new Toyota Harrier (and all of its colour options). The fourth-generation SUV migrates to the company’s TNGA platform – as do other new global Toyotas ­– along with a sportier design as compared to the outgoing third-gen model.
Inside, the cabin features a mix of leather and brightwork replete with an all-new dashboard design. A large 12.3-inch touchscreen sits atop the centre console. Touch-sensitive controls for the air-con system and touchscreen are positioned lower down, and the engine start-stop button is located even lower. The instrument cluster is a more conventional unit, sporting twin dials on either side of a larger MID display. You can head here for more info: https://www.autocarindia.com/car-news/new-toyota-harrier-revealed-416891
Image source
Toyota has just confirmed the return of the 'Venza' nameplate to the US market, and it 's pretty much identical to the fourth-gen Harrier that was revealed in Japan last month, save for branding.
In Japan, the new Harrier will be available with a naturally-aspirated 2.0-litre engine or a 2.5-litre hybrid, but the US-spec car will only be offered as a hybrid.
