CLEANING
Wash your car regularly to prevent rust. All cars are going to rust, however, you can delay this process by washing all salt and chemicals from your car immediately. A good wax can help you preserve your paint for a long time search for the best car shampoo available.
Claning your car interior with a good portable vacuum cleaner is equally important., and with covid-19 around you should also keep an check on air quality inside the car and should also install a good car air purifier to have fresh air inside the car.
EMERGENCY KIT
A spare tire and a jack are essential items to keep in your vehicle all of the time. A lot of cars come equipped with them. You would hate to be stuck somewhere you don’t know and need to pay a tow. You can save a lot of money by doing it yourself. Regular check the pressure in the tire for better driving stability and improved mileage performance. Use a handy digital car tire inflators to avoid issues related to a flat tire.
NOISE
Pay attention to any unusual sounds you hear when starting your car. Noise is something that can indicate a problem.
SERVICE
Needless to say get your car regularly serviced and do change your oil and oil filter periodically to keep your car engine in good health.
Don’t buy into the theory that you need a tuneup at 10,000 km. This is a rule of thumb that actually depends on the make and should not be followed religiously. You should follow the service and maintenance instructions provided by the manufacturer of your car.
Once you got your car serviced you need to test drive on a road with little to no traffic. Start out slowly to ensure a good repair is done well before risking higher speeds.
Keep a record of all the repairs that have been done on your vehicle over time. Keep these records inside your car. This will be of great help to you as well as for the mechanic to identify potential problems. It can help save time and costly diagnostic testing.
Consistency is very important when it comes to auto repair shops. Stick to a trusted mechanic whom you have used before instead of going around to various ones for repairs. Different shops have different opinions on your car. They could charge you more for repairs.
  • Make sure any mechanic garage you visit knows about your particular car model and brand. If you’re not sure, pay the extra to have a showroom dealer do the repairs. Although dealer mechanics can be hard on your budget, there are times when using them is absolutely necessary. The technicians at dealerships are trained to work on your particular model of vehicle you have. They have been trained for issues common to your car’s make. They also utilize regular auto repair training programs they take part in regularly.
When you are using a particular thing, you should have complete knowledge of it in order to experience better performance and increase its lifespan. If you have bought a brand new dream car to your home, then you should be aware of the fact that a car battery is treated as the heart of your car. Right from turning on your car engine and getting it started to charge your mobile phone on-the-go, make you enjoy your favorite music; a battery does all such important tasks and enables you to enjoy your car ride just like a racer. So, it necessary to take care of your car battery as you take care of a new special thing in your life – car.
Furthermore, most of the battery manufacturers in India are dedicated to providing high-quality car batteries so that people can enjoy their ride with the perfect performance of their battery. However, though you have bought the best car battery and lasts 2 to 5 years on average, it is important to take the utmost care for improved performance and longer battery life. Therefore, follow some of the important car care tips that are mentioned below and give regular attention to your battery maintenance.
  1. Drive Regularly: –
Batteries are manufactured with the use of chemicals and various components forming a circuit that provides electric power to the applications. This electric charge stored in the batteries results from the chemical reaction when the car is in motion. So, in order to maintain the level of charge in your battery, it is important to drive your car regularly.
  1. Check your car battery’s water level: –
Even if you buy the best car battery from the top brand in India, it needs a specific level of water that enables it to work in the normal condition. However, most of the car batteries that are available in the market have indication signs if it requires water. So, it is important for you to keep an eye on the water level indicator of your battery. Thus, if your car battery is in need of water, you can quench its thirst with only the distilled water available at the petrol pumps.
  1. Loose Posts or Terminals: –
Every car battery has two terminals i.e. positive and negative; and are connected to the specific parts of your car via cables or connecting wires. However sometimes, due to some cause, the connection breaks or posts become loose disabling the flow of current. In addition, corrosion on the terminals or moving your car on a bumpy road can cause the connection to loosen. Therefore, it is necessary for you to check the connection of the battery terminals and ensure they are tightened.
  1. Never Avoid Early Warning Signs: –
All electrical appliances or machines including batteries expose some negative signs called warning signals when they tend to decrease their lifespan. So, if your battery ever shows negative signals like cranking sounds and short circuits, you need to look after your battery maintenance and solve such issues in order to increase the life of your battery.
  1. Clean battery case increases its life: –
Last but not the least, it is very important to maintain your battery case clean – free from dirt and moisture. If your car battery is more prone to dirt and moisture, then your battery life lessens than it should be. So, for a longer battery life and better performance of your car, keep your battery’s case and terminals free from dampness and dirt.
