dd_pac28
Radials for Indigo?
There are many brands available in the market but choosing one depends on what you want from your tyres. The Potenza GIII's are good tyres, go ahead if you like them. Get tubeless tyres though.
I suggest if you have the Budget, try Michelin Pilot Preceda 2 in 195/60 R14 size.
This should provide you with the best possible compromise between ride & handling . If they are too expensive, do try Bridgestone, But i wouldn't go near Goodyears as earlier experience says even though the are cheaper, they tend to be noisy in the long run.
I hope this helps.!!
the current stock tyre size for indigo is 175/65 R14 isn't it?
