kay.dee
Engine Repair for a 7 year old Ecosport
Hi All,
I have a 2013 EcoSport 1.5 TDCi which has clocked around 97,000 kms on the odo.
Since the past couple of months it started giving white smoke for the first start of the day. I got it check at the authorised service centre and they performed a compression check on the engine and following were the readings found:
Dry             Wet
12:50         13.50
11               12
11:50          13
11                12.50
After this I made a top-up of the engine oil and started running the car. After 4,000 kms my engine oil was almost dried up and topped up on time because I was keeping an eye on the same.
The service centre has given me an cost estimate of between ₹ 40,000 - ₹ 1,20,000. My only concern over here is, should I move forward with the repair, as the car is out of warranty. There are no other issues with car.
Any expert opinions please.
P.S: Sorry in advance for any typos or grammatical errors
Thanks in advance.
