VET5
Updated Royal Enfield Himalayan: A close look
Royal Enfield has launched the updated Himalayan, with prices starting at Rs 2.01 lakh (ex-showroom, Chennai). This means it costs around 10,000 more than its predecessor.
in terms of overall design, the bike remains largely the same as before. The most significant differentiation factor is the new colour schemes that the bike will be available in. These include the Granite Black and Pine Green colour schemes.
It also features an additional pod on the right side of its existing digi-analog instrument cluster. This system is the same Tripper Navigation unit that made its debut on the new Meteor 350. Another change is in the metal frame that is mounted towards the front of the tank. You can head here for more info: https://www.autocarindia.com/bike-news/updated-royal-enfield-himalayan-launched-at-rs-201-lakh-419910
Came across a few images of the updated Himalayan, finished in Mirage Silver.
Source 1
Source 2
I think the design is quite good. The aesthetic is there and the specs did not have to suffer for the design. Maybe a few more tweaks on the wheel itself would make it look really better. There are many other rims out there that can make it look good. Other than that, this is a clear 10/10. I believe that there is just one more thing missing, the custom design on the engine. Maybe we can spare another budget for that to get a much better one on the bike so you could enjoy it to the fullest.
I just took Delivery of New 2021 Himalayan last week, THE BRAKES ARE WEAK  KEEPING LIFE IN DANGER, This is the 1st important point noted, Engine was smooth Suspension is Slow To react And Felt Basic  Doing good job ,Head light  illumination is good in cities under street lights ,Need to upgrade the Bulb to ride away on high way , I Think This Time frame is Welded properly as per Salesman ,
i used to own 2016 bike Sold On hearing the Chasis cracks issue,
Edited by reddy
