Hyundai i20 Key not inside the car error.
suvadeep24
 Share
Hello, I have a Hyundai i20 (CRDI - 2017 model - Asta Optional). Recently I am facing a weird problem with the smart key. The car is showing an error "key not inside the car". It is happening only at night time and not on daytime. Today what happened is when I dropped my friend and he closed the passenger side door after getting out of the car the error key not inside the car popped up in the dashboard. I tried to press the buttons in the key but no solution and beep sound kept on and once I put the car in 1st gear and started to move it stopped. Once I reached home and came out of the car to open the garage the same error popped up. The key was inside the car I have checked. But this does not happen during the daytime when the lights are not on I have checked today only. I got this error for the second time today and both during night time. Anyone faced this kind of problem and any solution for this? Battery in the key is okay and in good condition. Thanks.
Link to comment
 Share
