One is illegal - put bigger bulbs the other not desirable - replace with gas discharge lamps(bulbs + electronics). I hear there are some bulbs from Osram and Philips which are claimed to have improved night and wet weather illumination, but have no experience with these. I doubt how much the can help.
There was extensive discussion about projector lamps etc. in another topic.
Well to fit a Xenon you need a projector lamp .Increase the wattage of your bulb .If not the headlamp put it in the fog lamp .If you don't have a fog lamp then get one ..Remember the bright bulbs should be placed lower so that the eye strain to on coming traffic is reduced.
