2009 Mercedes-Benz SL65 AMG
speed
Starting with the standard SL65 AMG , Mercedes' in-house AMG
Performance Studio tweaks the 6.0L V-12 bi-turbo engine for a full 670
hp -- 58 horses more than the SL65 -- while the torque figure remains
identical at an electronically limited 738 lb-ft for drivability
reasons (AMG claims that 885 lb-ft would be available in derestricted
form). To achieve these gains, larger turbochargers were developed
specifically for this application, while a new AMG sports exhaust and
optimized airflow tubing round out the power boost. The result is a
heart-pounding 3.9 sec sprint from standstill to 62 mph and an
electronically limited top speed just a single mph shy of the magical
200-mph mark.
Such an increase in performance isn't limited to
the power increase alone. Weight savings paired with the horsepower
boost provide less mass for the newfound muscle to push around. In
fact, Mercedes claims a reduction of a massive 551 lb from the SL,
though the total curb weight still comes in over the two-ton mark at
4123 lb. To achieve such weight loss, Mercedes constructed many of the
SL65 AMG Black Series' body panels out of lightweight carbon-fiber
composite (CFRP), while also giving the car a fixed roof made from the
same material, with an integrated roll bar. The advantages of the new
lightweight roof are two-fold: increased structural rigidity and a
lower center of gravity.
As
expected on a car of this type, various aerodynamic aids have been
implemented to not only give the appearance of added performance, but
to actually perform the task. A concealed CFRP rear spoiler will raise
at speeds exceeding 75 mph, while a wider front apron incorporates new
carbon splitters to direct airflow in an optimal manner. Out back, a
carbon rear diffuser fits neatly between the outlets of the new sports
exhaust system.
Link to comment
Brakes and suspension have also been tweaked
for Black Series duty, with larger discs at all four corners,
supplemented by six-pot calipers up front and four-pot items in the
rear, covered by 19- and 20-in. black AMG wheels at each respective
end. Rubber comes from Dunlop (AMG's DTM partner) in the form of a set
of Sport Maxx GT tires. A new adjustable coil-spring suspension is
fully adjustable for track duty, and the track has even been widened by
3.8 in. in the front and 3.3 in. in the rear. Meanwhile, weight has
been reduced in the new aluminum wheel carriers and the spring links,
camber struts, and pull/push rods at both axles are all of new design.
The
standard AMG Speedshift Plus five-speed automatic transmission is
retained from the standard SL65 AMG, likely deemed suitable as a result
of the nonexistent torque increase. The transmission features four
modes with varying degrees of comfort and performance and an automatic
rev-matching feature on downshifts. Three-mode ESP is fitted in
conjunction with a limited-slip differential with 40-percent locking
capability to keep power delivery optimized and the car pointed in the
right direction.
Link to comment
smiley17.gifYup!!!the new 2009 merc SL 65 IIIIIIAMG looks cool n with with more power it will be a fun to drive......i love all the mercs specially those IIIIIIAMG's with more power (I get to know the fullform of AMG from this month's ACI issue...thats Aufrecht Melcher Grobaspach...i think u all will be knowing about this)....its all black sporty interiors are also very....very nice....smiley20.gif
Link to comment
@vibhor, dont worry buddy , even Ive learned AMG full form through your post.
@rssh, why  all  good things come at such huge prices?
Just read your msg. , for what studies are you going to KOTA? Anyway , best of luck , your presence will surely be missed.
Link to comment
Archived
