understanding max torque and power
rithu09in
Hi Team,
  I would like to understand what is max torque and power that Car companies specify in technical specs... It would be something like the foll
Max. Horsepower (ps/rpm)
94/5500
Max. Torque (kg m/rpm)
12.5/3500
I understand that these numbers are w.r.t to RPM's... what does this indicate?
Is it that the car which gives you max power and torque in lower RPM's is better or is it vice versa ?
Link to comment
If you forget the constants the power is just torque multiplied by the rpm.
Power = constant * torque * rpm
This is the reason why peak power is at a higher speed than peak torque.
In general for best results you should try and keep the rpm between (just blelow) peak torque and (just beyond) peak power. This is why you have a rev counter in most cars today.
Link to comment
Power increases till max rpm reached.
Max Power comes at some rpm less than Max RPM.
Example-
In Tata Indigo XL's Owner's Manual, it is given that "Max Power is 70Ps at 4000 RPM as per DIN 70020", "Max Torque is 140Nm at 1800-3000rpm as per DIN 70020".
The Engine of Tata Indigo XL can be revolved upto more than 4000 rpm (around 4500-5000rpm).
So Max Power is obtained below Max RPM.
Link to comment
In general for best results you should try and keep the rpm between (just below) peak torque and (just beyond) peak power.
SG, you are making mistake. I think you want to say try and keep the rpm between (just above) peak torque and (just below) peak power.
Link to comment
This is normal. Max rpm is the limit to which the engine can be taken to without damage.
The torque drops off rapidly as you near the peak rpm. The power (rpm*torque)  follows suit. So the peak power is invariably somewhere below max. rpm. Revving beyond this limit may damage the engine. Modern EMUs do not allow you to over-rev.
sgiitk2008-08-07 18:08:42
Link to comment
A very good answer, exactly. From the above formula, many might be wondering if increasing the rpm would simply increase the power. And many do believe in that and throttle fully without realizing that it does not really help, because the torque suddenly dips beyond certain rpm, resulting in lower power.
Link to comment
  • 1 year later...
Archived
