Tinted glass is window glass which is not fully transparent. The idea (legitimate) is to block out some of the heat and light. Film is often applied retrospectively. The law requires a minimum of 70% transparency in the front and rear screen, and a different level in the side glasses.  (guru's may please correct me if the numbers are wrong).
the side windows should be 50% transparent and the front windshield should not be tinted. It is illegal. atleast here in hyd
I think the same MVA applies across the country. The minimum transparency for the windscreen specified is 70% and it is somewhat lower for the other windows.
