praji.ooo 0 Report post Posted August 12, 2008 after a long run the radiator fan may remains working, is ther any problem to stop the engine at this moment? some says that we must wait till the fan stops , is it true? Quote Share this post Link to post Share on other sites
nikvint 1 Report post Posted August 12, 2008 it depends on the car you own. The current generation car are not require to be kept on till cooling fan stops. Even if you switch off ignition when the cooling fan is running it will not affect the engine. Quote Share this post Link to post Share on other sites
