SADesigns
Sound & Vibration Damping
Hello Friends,
We have imported a small consignment of Sound & Vibration Damping products.
Have made custom sized kits for different application.
Hatchback  - Sedan - High end installs
This
material has sandwiched fiber mesh for reinforcement and it is a marine
grade material heavier and denser and more effective then others
available in the market.
Type 1 and 2 are different materials. A combination of these have been given in each kit.
easily applicable and usable sizes of
Type
1 - 4" x 24" ( fiber mesh sandwiched in between 2 layers of bitumen,
one side has a permanent protective poly cover and the other has a peel
off paper to peel and stick, very high quality adhesive too, with just
4 mm thickness it would not hinder anyother articles in your car and
will add much more wight as compared to other damping products
available in the market. This material weighs 0.36kg / sqft )
Type
2 - 6" x 8" ( fiber mesh sandwiched in between 1 layer of shock
absorbent composite layer and the other a butyl layer with bitumen
filler, this too is an easy peel off application. It is 5 mm thick and
weighs 0.58kg/sqft )
At this juncture we are giving out kits at
very very low prices...to see the market response. Very limited stock
is available and more shall be ordered if we see a growing demand.
Check the link for further details and pricing
www.box.net/shared/yubovdixry
Have fun..
Fenil Mehta
Sound & Acoustic Designs.
www.sadesigns.in
PS:
Shipping/ Transport / Courier cost will be borne by you. Demand Drafts
and Account Transfer will remain the only mode of payments. Material
shall be dispatched only upon realizing full payment.
1-2 Kits if ordered will be given at the Dealer Price. If you order 3 or more Kits then you can get them at the distributor rates.
SADesigns2008-12-10 11:13:49
