sudeepd
Adjust Chain Slack,Carburettor Idle,Air-Fuel Screw
Hi there again,
              Can anyone please tell me==
              1. How much
chain slackness should be kept for Bajaj Pulsar 180DTSi (LCD Speedo)
and how to measure it (Should it be measured just by moving the chain
up and down and measuring that distance)?
              2. How to find out the air-fuel ratio is correctly set or not?
How
much turns should the air-fuel ratio screw be turned anticlockwise
after fully tightening the screw for proper combustion (i.e how to set
the air-fuel ratio of 14:1)?
              3. How to adjust the
idle rpm. If the rpm is kept a little bit high (to avoid stalling the
engine when it is cold) then the rpm rises too much when the engine has
warmed up. If the rpm is kept a little bit low (since the rpm rises too
much when the engine has warmed up) then the engine stalls when it is
cold.
PLEASE REPLY SOON.
