Darshan Posted January 20, 2009 Report Share Posted January 20, 2009 Hi All, I have a head unit which is DEH-P5750MP which is connected to Rear speakers on a tray and then 2 speakers on the front door. Not sure of the speaker specifications but the rear one is a Pioneer which is 3 way i guess and then front speakers are sony. Now the rear speaker has a wierd noise on DRUMS, only one side the other is fine. Now i have disconnected one speaker. Was thinking of replacing the speakers, but then was thinking if i replace the speakers the tray noise is always a pain. So planing to remove the tray and buy a component for the front door and move the front speakers to rear door. Now i need suggestion. If you guys think component is the best solution, suggest a model. Not thought of budget so not mentioned. Also not interested in SUB or AMP as this car is used very less. Regards, Darshan Link to comment Share on other sites More sharing options...
trojan_virus Posted January 20, 2009 Report Share Posted January 20, 2009 Well without having a amplifier , u wont get the optimum results from a component speaker and we need a budget plz ;D Link to comment Share on other sites More sharing options...
Darshan Posted January 20, 2009 Author Report Share Posted January 20, 2009 Well i am ready to spend around 5k. Not more than that cause i am planning to sell this car in sometime. Link to comment Share on other sites More sharing options...
pritm Posted January 20, 2009 Report Share Posted January 20, 2009 Darshan.. Its always good to have Co axials in the rear and components in front with Tweeters since they will balance entire freq range. This config is OK if you don wish to have sub. I prefer JBL and its working good with me Link to comment Share on other sites More sharing options...
5u3zEr0 Posted January 21, 2009 Report Share Posted January 21, 2009 You can also try Blaupunkt components, they will come in your budget and are pretty good. And with 5k I think you can buy the Blau velocity range, which are higher end. There are other brands like Polk Audio, Boston Acoustics but they could be expensive. Check in the market. Also you are making a good decision on spending for better front speakers than on the rear. Link to comment Share on other sites More sharing options...
Darshan Posted January 21, 2009 Author Report Share Posted January 21, 2009 Thanks all. Is it ok with out an AMP or will that sound like normal speakers with out AMP? Link to comment Share on other sites More sharing options...
5u3zEr0 Posted January 21, 2009 Report Share Posted January 21, 2009 They should be fine without an amp for normal listening. I am sure they will sound better than the stock front speakers which are currently in your car. I assume the front speakers came with the car. Link to comment Share on other sites More sharing options...
Darshan Posted January 21, 2009 Author Report Share Posted January 21, 2009 No Actually i got a sony fitted 2 years back, They are good. Link to comment Share on other sites More sharing options...
5u3zEr0 Posted January 21, 2009 Report Share Posted January 21, 2009 Then either of these components you choose will be better . Personally I like the Blaupunkts, they sound sweet not too bright and last long, my current pair is now 8 years old! Link to comment Share on other sites More sharing options...
Archived
