sudeepd
Don't always use the clutch for changing up gears?
PLEASE ALL NOTE THE SHELL SITE TALKS ONLY OF BIKES AND NOT CARS' date=' DO NOT TRY IT ON CARS!!!!![/quote']
Anijog and DTandon,
               Please go through this Manish's Post=>
I don't use the clutch many times. It takes a lot of time to master the
technique' date=' but it can be done. You need to match the revs and speed and
known when to shift. It can be done and if done properly, it will save
you from wearing the clutch.
FRG[/quote']
                    So Now What will you guys say about Manish?
Manish also does not (many times) use Clutch while shifting Gears (of Safari, I guess. Correct me Manish if you use Bike).
Manish said he many times shifts Gears without clutch. He did not specify Up shift or Down shift.
May be he might be up shifting and down shifting too without clutch.
Period.
      Manish,
                Please Put Some Light on Shifting Gears Without Clutch on Your Safari.
Sudeep.
sudeepd2009-03-02 14:15:31
