harshalraj2006
amps and woofer for city zx
A bass tube like the name suggests will be a tube with the woofer inside it, whereas a normal can be mounted on your cars rear tray for a free air setup or in a ported or sealed box depending on the subwoofer and the type of bass you want. It's upto you to decide how you want it but generally the sub woofer is mounted on a box.
Bass tube gives a loose bass whereas an enclosure will give a tight punch. It depends on the user whether he/she likes loose/tight bass. My choice will be a good enclosure. I can say this coz i have experienced both in my Honda.
Still, while buying do check both of them.
cheers
