sudeepd
Location of Oil Strainer in Pulsar 180DTSi (LCD Sp
Hi there friends,
          Can you please tell me where the oil strainer is located in New Pulsars. If you observe some of the bikes, the oil filter is located ahead of the Engine Oil Chamber and is fitted by using 3 bolt-on screws. You can check the XCD below which has Oil Filter as pointed by arrow.
The photos of XCD are given below.
The owner's Manual of Pulsar recommends Cleaning of Oil Strainer not replacement like Oil Filter.
 You all know Oil Filter is Different than Oil Strainer.
 Pulsar and Scooty Pep have Oil Strainer. This Strainer needs cleaning while replacing the Engine Oil.
But XCD, Fiero, Star City, Apache have Oil Filter. This Filter needs to be replaced while replacing Engine Oil.
So please tell me the location of Oil Strainer in Pulsar and how to reach it (Means how to open it).
Thanks.
