anijog 0 Report post Posted April 29, 2009 The sensor is a temp sensors, there are two i guess, one at the radiator and one at the AC vent. The temprature thermostat is controlled by the sensor in turn controls the start stop of the compressor thru the ECU. If you find vibrations without AC when you pick up from idle then you need to examine the clutch plates. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 5, 2009 The replaced sensor is T.P sensor Rs 1750. Now the vehicle is smooth. Which replacement headlight bulb should I use as the beam throw of the existing bulb is inadequate. I am considering only 60/55 bulbs. Philips claims 20-50m longer throw on extreme light model (60/55). Or are there any other advisable brands/models. Quote Share this post Link to post Share on other sites
anijog 0 Report post Posted May 5, 2009 Ok if your headlamp beams are clean, i.e. the seals intact, the relectors and the glass should be clean and shiny, if the sealing is not good in the rains they will cause moisture to seep in examine the rubber shoes which sit on the lamp terminals behind and the heat diffuser ducts, they should not be choked, they are small tubular openings at the back or can be gill type, then you can go for RALLY 100/110 with cut outs. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 6, 2009 Huh... more tears!!!!... The speedo stopped working. The Rpm, fuel, heat meters work. When trying to fix it(the repair dint workout as well), the instrument cluster gauge face tore. If at all the repair works out, will I get a gauge face separate from anywhere?? I checked with the local market here but no avail to this. Quote Share this post Link to post Share on other sites
sudeepd 0 Report post Posted May 6, 2009 Please file a complaint in a Consumer Forum against the Dealer who sold you a Scrap Car. I don't mean Accent is Scrap but the model which he sold you is scrap. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 6, 2009 Any helping hands???? Where do I look for these parts (used or non oem)? Instrument cluster assembly from showroom is a whopping app: 7k . Delhi and Bangalore are accessible city for me though I am in kerala. Quote Share this post Link to post Share on other sites
dtandon 0 Report post Posted May 6, 2009 You will need to look around in local garages and scrap dealers for an accent that's been totaled and get what you need from that. Ask (or pester) the guy who was repairing your meter. The meter itself should be repairable. Quote Share this post Link to post Share on other sites
rssh 59 Report post Posted May 7, 2009 I think you go for aftermarket speedometer but thy won't fit like the stantard but are reliable enough try pricol (which is std in many cars as OEM) it can come at 3-4k. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 11, 2009 As anijog said, the replaced sensor for that vibration when switching on the a/c was a temperature sensor. And after the replacement, now there is no evident vibration. But I thought this sensor is something to do with drawing power from the engine when the a/c is on. But there is no increase in the rpm(this is what i thought) even if the ac is on(sgiitk mentioned this rightly earlier). So now what does this temperature sensor actually do? Quote Share this post Link to post Share on other sites
sudeepd 0 Report post Posted May 11, 2009 The Temperature Sensor provides Signal to the Temperature Gauge on the Instrument Panel through ECU. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 11, 2009 As anijog said' date=' the replaced sensor for that vibration when switching on the a/c was a temperature sensor.[/quote'] Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 11, 2009 guys i am really sorry, the replaced sensor was t.p sensor. I thuoght t.p stands for temperature sensor, but now when i googled I got a different result; Throttle position sensor!!!!! Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 19, 2009 Huh.. an update.. The vibration at first gear has popped up evidently now. So this time I gave the car to hyundai. They identified all the three engine mounts have cracked and needs immediate replacement. Quoted 6k. I have bought this car anyways, so gona resurrect her whatsoever. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 25, 2009 Hi all, I am in a real jeopardy now. When I showed the car to the hyundai Ass last day, they advised me to conduct a complete engine overhaul(94k done). And also when I pointed out that when fully loaded the car easily bottoms out unusually, they say the strut and suspension too needs overhaul. I know its common in accent to scrape bottom; but here when fully loaded, apart from the belly, the rear and front bumper kisses the road at patchy surfaces. So I move dead slow. The engine and suspension overhaul was quoted at a 40k approximately. Now my question is; Is it worth spending this much? And even if I do those overhauls, can I make sure that everything could be close to fine condition? Or something else may stop working tommorow? I plan to keep the vehicle for 2-3 years. What do you say forum..... Quote Share this post Link to post Share on other sites
sgiitk 0 Report post Posted May 25, 2009 I would go for the suspension job, and hold on the engine job.Get the mounts changed. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted May 27, 2009 I would go for the suspension job' date=' and hold on the engine job.Get the mounts changed.[/quote'] I too feel thats a good idea. I spoke to a person in a garage, he too recommended this. So gona leave it for the suspension job today. @sgiitk sir, Could de-carb do any good at this stage? The power is comparatively less(but can surely live with it). The tyres now are 185/65r13 and is due for a change. I have two options in my mind. 1)175/70r13, the stock size as it gives the car a slightly higher height (I am more inclined to this option) 2)185/70r13, solely for height. will this harm the suspension set up. Quote Share this post Link to post Share on other sites
anijog 0 Report post Posted May 28, 2009 Could you post a pic of the car's stance on a flat road surface, need to examine that and also pics of your car tires to consider the impact of the suspension on the tires. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted June 5, 2009 @anijog, couldnt post anything as I was out of the town for some days. Did the de-carb meanwhile, but dint find any change at all. I thought I would be able to feel some (atleast)iota of a change. Changed the engine mount. While at the A.S.S, I asked 'em to inspect the suspension too. And they found all the struts except one at the front left to be leaking. They advised me to change all the four at a time instead of three, as it could invite weight imbalance. app 13k. But dint do it yet. Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted June 10, 2009 Hi, I was unable to login to autocarindia for a few days. Then I changed my default search engine and it worked. I switched my A.S.S. to another one here as I was'nt happy with them. Now the vehicle is with them for the suspension job. Hey, as u may know, my drive shaft problem was fixed by changing the axle boot. But now again it has poped up. So, this time I think I its wise to go for the axle change. (At ass its some 18k and outside its 3.5k!!!). I just wanted to know how long can the vehicle run with this strong clicking sound while turning....? Can running with this, cause any potential harm to some other parts... How critical is this...? Quote Share this post Link to post Share on other sites
luukie 0 Report post Posted June 11, 2009 how long can the vehicle run with this strong clicking sound while turning....? Can running with this' date=' cause any potential harm to some other parts... How critical is this...? [/quote'] Or is it ok to run with this noise for some more kms...? Quote Share this post Link to post Share on other sites
goenkakushal 30 Report post Posted June 11, 2009 Well according to me you can run ur car with this noise until it starts to make this noise even while going straight or on slight turns. If it starts while going straight there are chances of axle breaking which means breakdown. So make sure you get the job done when this noise starts on slight turns.. Quote Share this post Link to post Share on other sites
kapmalik 0 Report post Posted June 11, 2009 Hi there, please let me know which type of fuel is best for Accent 2008 whether premium or ordinary. Best wishes, Kapil Malik Quote Share this post Link to post Share on other sites
rssh 59 Report post Posted June 11, 2009 Ordinary will be good as it is not a high compession engine. Quote Share this post Link to post Share on other sites
sudeepd 0 Report post Posted June 11, 2009 Well according to me you can run ur car with this noise until it starts to make this noise even while going straight or on slight turns. If it starts while going straight there?are chances of axle breaking which means?breakdown.?So make sure you get the job done when this noise starts on slight turns.. Is it good option to drive the car with "that clicking noise coming only at full turns" unless it start coming while Driving Straight Too?Any other members Backing this Solution? I am facing same Issue with our Old Indigo LS (1,65,970kms). The noise comes from the Left Front Side while taking Right U-Turns Only. Quote Share this post Link to post Share on other sites
rssh 59 Report post Posted June 11, 2009 @sudeep check your axel or else the suspension is making noise . In my case it was a case of axel and we had to replace it. Quote Share this post Link to post Share on other sites
