praveen123
sony Xplod
My budget is 3k and i plan to buy sony Xplod? Amplifier  - this fits my budget - request you to please let me know how is this before i buy
I have pioneer 6150 + JBL speakers in my Santro AMPS i want to add now
MOSFET Power Supply
Maximum Output Power: 2 Ch x 110W at 4ohm
Maximum Output Power: 1 Ch x 350W at 4ohm
Maximum Output Power: 2 Ch x 150W at 2 ohm
Rated Output Power: 2 Ch x 60W at 4 ohm(1.0% THD)
Rated Output Power: 1 Ch x 130W at 4 ohm (0.1% THD)
Rated Output Power: 2 Ch x 65W at 2 ohm (0.1% THD)
Low Pass Filter (Rear): 80Hz, -18dB/oct
Frequency Response: 5Hz-50kHz
Signal-to-Noise Ratio: 97dB
Dimensions ( W x H x D in mm): 321 x 55 x 200
Praveen, for 3k this is the best you could get to my knowledge or you will have to buy a small Pioneer 2 channel amp from the grey market, which I don't think you are inclined towards.
Though there are better amps in the market you will need to double your budget for them which I don't think is necassary for an entry level setup. Get this Sony amp from a dealer with warranty and enjoy the music dude!
