sudeepd
ULSD cut the life of Fuel Injectors & Fuel Pumps?
http://www.ultimatesyntheticoil.com/Improve_Fuel_Economy/Increase_Fuel_Economy.htm
Just have a look at the below point
"Further, because ULSD can otherwise cut the life of fuel injectors and
fuel pumps in half, Federal regulations require gas stations to add (for the first
time) performance additives to the new Ultra Low Sulfur Diesel (ULSD)" mentioned in the DIESELS: under "17. Use a Good Fuel Additive" tip.
Does Really Ultra Low Sulphur Diesel cut the life of Fuel Injectors and Fuel Pumps?smiley18.gifsmiley3.gif
sudeepd2009-06-04 12:01:50
Well I don't really know that but we must not worry about it in India coz it might take a decade to get ULSD in India . I don't really know how sulphur helps injectors.
I did not say Sulphur helps injectors.
In fact I posted Sulphur Eats up the Life of Fuel (Diesel) Injectors and Fuel (Diesel) Pumps.
