kain
Problems With Honda Shine.
hi,
i bought a honda shine(front disc) last year. throughout this year, am fed up th the following probs...
1. poor brake biting
2. brakes are not effective
3. poor gear shifting.
i wanna know abt the views of guys who r drivin shine
The answers are not corresponding to your Question Numbers.
1.For Front Brake, check the Pads if they are worn and replace if necessary. Also check the thickness of the Disc at the same time if it within limits.
2.For Rear Brake, clean the Drum Shoes and the Inside of the Drum with Sand Paper. Check if the Shoes are worn and replace if necessary.
3.For Poor Gear Shifting-
     a. When was the last time you Changed Engine Oil? Please mention the Former Reading and Current Reading.
     b. Get the Clutch Play adjusted as per Honda Recommendation.
