Gurkha
Turbonator
None of it is relevant at this point, its a theory which needs to be implemented, btw, ISI mark is also on certain biscuits and other stuff, doesn't make them good in any sense. JIS, SAE and DIN are what we are after.
Also its a US product, ISI mark is out of question there.Gurkha2007-10-28 18:27:38
Looks interesting. Needs to be checked out by a few others before we can be sure!
The additional vortices in the inlet should encourage better air-fuel mixing in the manifold. On the negative side is may marginally reduce the volumetric efficiency by adding a little additional 'obstruction'.
Actually these things never work' date=' if they did, the manufacturers would surely implement this.[/quote']
Exactly. When you fit any of these devices they always advise you for a 'tune up' The gain you get is from the tune up and not the device.
