reddy
Why do FWD cars have transmission tunnels
BTW
always wondered why it is called transmission tunnel
the transmission is the gearbox, and that is up ahead, if at all it comes just after the dash under the central console
the tunnel is for the prop shaft or the propellor shaft
BTW
In RWD cars the prop shaft transmits the power to the wheels hence the term transmission tunnel.
