suvadeep24
Need Help...
I own a Yamaha RX 135 4 speed, which 5 years old and has done 45000 km.
I want to go for some minor modification..
Will it be wise enough to for RX 135 5 speed sprocket for improvement in speed???
I will also be going for expansion chamber, NGK Iridium spark plug and RDD CDI..
Please I need Your help..
Thanks in Advance..
If you mean an extra gear, then its impossible..But you can change the sprocket size (meaning a sprocket with more teeth) can be fitted to increase speed but decrease acceleration and vice versa..
Iridium spark plugs for bikes, im not so sure and expansion chamber? Changing a CDI unit too is impossible as far as i know
1>CHAIN SPROCKET....
BIGGER FRONT AND SMALLER BACK---TOP SPEED AND MORE AVRG
SMALLER FRONT AND BIGGER BACK---TOP ACCELERATION AND LESS MILEAGE....
2>(NGK OR DENSO BOTH AWESOME) IRIDIUM SPARK PLUG GOOD OPTION COST 500RS + ALSO CHANGE THE SPARK PLUG WIRE WITH HIGH PERFORMANCE CABLE (SPLITFIRE IS GOOD ONE )--650RS
3>BUDDY YOU CAN GO FOR K&N UNI RC1060 AIR FILTER..
RC---IS OILED AND R---IS WITHOUT OILED...1600RS BUT DON'T FORGET TO PUT BIGGER JET... CHANGE THE MAIN JET..ONLY....
4> RE BORING IS GOOD OPTION...
5>RDD CDI ONLY IF YOU HAVE IMPORTED KIT NO NEED TO INSTALL INDIAN KITS BUT MY OPINEAN RX-135 WAS LAUNCHED WAY BACK AND IT'S BUILD IS NOT PERFORMANCE FRIENDLY(BUT IT'S A SURPRISER NO ONE KNOW WHAT IT CAN DO) SO IF YOU WERE ASKING TO INSTALL KIT IN PULSAR 180 OR BIGGER CC BIKE... I WOULD SAY GO FOR IT BUT NOT FOR RX-135 VERY MINUTE EFFECT IN IT..SO WASTE OF PENNY....smiley1.gif
