samlnt
honda stunner 5th gear swap with unicorn overdrive
I have a honda stunner, bike is good but u cant drive past 50kmph as engine rpm seems to be high, 4th n 5th gear ratios are almost same. It took me several months to understand which gear am driving 4th r 5th.
i think unicorn, stunner n shine share same crank case. so Center distance for gear pairs must be same. I think if i can swap unicorns 5th gear  pair to stunner it could lower engine rpm n i can get a better mileage also.
please tell me if i can swap unicorns 5th gear pair n what extra parts i would require.
thanks in advance
Honda has done a lot of R&D on Stunner.
The Rpm of Engine at 50kph comes to about 5000-5500. Yes thats high rpm but not Very high Rpm Range. So don't worry.
How much distance has your Stunner covered yet?
Don't go above 5000rpm for initial 1000kms.
