sgiitk Posted August 19, 2010 Report Share Posted August 19, 2010 75k for ABS looks like robbery. Should be more like 15-20k. Link to comment Share on other sites More sharing options...
abhpom4u Posted August 19, 2010 Report Share Posted August 19, 2010 Since ABS is an electronically programmed device attached to the braking system, can it be done at an after-market fitment..?? Is it possible..?? Link to comment Share on other sites More sharing options...
sgiitk Posted August 20, 2010 Report Share Posted August 20, 2010 Since ABS is an electronically programmed device attached to the braking system' date=' can it be done at an after-market fitment..??Is it possible..??[/quote'] There are a lot of sensors involved as well. Even if possible (only as a retrofit in a car which has it in some models) I will advise against it. Unless done by a real expert tinkering with the safety systems is a big no-no. Link to comment Share on other sites More sharing options...
abhpom4u Posted August 20, 2010 Report Share Posted August 20, 2010 @sgiitk sir: Thank you for clearing my doubt.. I was in a perplexed situation as to why is ABS never retrofitted and also never heard of having such thing done.. I had asked many people, but all they say is that such a thing is not possible, never got any reason from anyone untill now.. The reason why I am more keen to know about the ABS thing is because I am looking forward to buy a car by early 2011.. Link to comment Share on other sites More sharing options...
Alok Mathur Posted August 24, 2010 Report Share Posted August 24, 2010 Friends,Let me clarify first that I had never drove (even never in any automatic transmission car). Now please clear my one doubt Link to comment Share on other sites More sharing options...
sgiitk Posted August 26, 2010 Report Share Posted August 26, 2010 In an AT car when you are in the Low(er) ranges or in the Sports mode the reverse braking is active. At one time AT cars had 'beefier' brakes than their MT cousins. In any case it is a fact that the brake pads wear out faster in an AT! Link to comment Share on other sites More sharing options...
sb-alto Posted August 26, 2010 Report Share Posted August 26, 2010 Q) Do fog lamps operate at higher temperature than normal halogen headlamps? (Not talking about colour temperature) and do they consume more power compared to halogens ? Link to comment Share on other sites More sharing options...
sgiitk Posted August 26, 2010 Report Share Posted August 26, 2010 @sb-alto: They use the same technology as ordinary lamps. Wattage is normally the same or lower but there is no bar on 100/150W jobs! Fogs normally have a different (wide) distribution of light. sgiitk2010-08-26 11:14:48 Link to comment Share on other sites More sharing options...
praji.ooo Posted August 27, 2010 Report Share Posted August 27, 2010 In majority AT cars there is option for gear down and up, which is operated by moving the gear lever to minus and plus sign respectively in drive mode. Now modern AT cars have paddle shift as seen in F1 cars. Link to comment Share on other sites More sharing options...
sgiitk Posted August 28, 2010 Report Share Posted August 28, 2010 In majority AT cars there is option for gear down and up' date=' which is operated by moving the gear lever to minus and plus sign respectively in drive mode...[/quote'] He is talking of engine braking! In an AT car if the engine speed is lower than that corresponding to the road speed then the transmission is 'declutched' ie freewheels. In paddle shift cars if you go into the 'sports' or 'sequential' mode the reverse braking is activated. In a Honda Civic/City AT in S the fifth gear can only be selected manually, but that is a different matter. Link to comment Share on other sites More sharing options...
dr_nishu Posted August 29, 2010 Report Share Posted August 29, 2010 Why there comes the Smell of Fuel in the car while Re-fuelling the car, at filling station even if All the Doors & Windows are in closed position ?? dr_nishu2010-08-29 16:45:08 Link to comment Share on other sites More sharing options...
sb-alto Posted October 7, 2010 Report Share Posted October 7, 2010 @nishu : Have you checked if the ventilation is open or not. Fuel vapours are very light and need slightest gap to enter. (I mean large intermolecular space./ or is it ?). I think SG sir will be the best one to explain gas behaviours. Myth or Fact ? 1. Do diesel engines have less running life than a petrol engine? 2. Releasing clutch early or releasing it slowly? Which is a better practice ?(People say releasing early is better as it provides efficiency) 3. A car without AC has more life than a car with AC? Is this true ? Link to comment Share on other sites More sharing options...
Alok Mathur Posted October 10, 2010 Report Share Posted October 10, 2010 Myth or Fact ? 1. Do diesel engines have less running life than a petrol engine? Before 10 years Link to comment Share on other sites More sharing options...
dr_nishu Posted October 12, 2010 Report Share Posted October 12, 2010 Have you checked if the ventilation is open or not.Myth or Fact ?1. Do diesel engines have less running life than a petrol engine?2. Releasing clutch early or releasing it slowly? Which is a better practice ?(People say releasing early is better as it provides efficiency)3. A car without AC has more life than a car with AC? Is this true ? That's the case I've experienced in my friend's Swift VDi. Yes, It was having Windows closed, Air-Con On with Re-Circulation mode at that time, when I got the Diesel smell at the filling station. Answers to your queries; 1) Yes, their Comfortable life is around 5-7 years, whereas a Good Quality Japaneese Petrol engine will even not show the l'll bit sign of Ageing in such time period. Whereas Tata engines are having lesser life, max 4-5 years of Routine usage for both Petrols & Diesels or 1.5 lakh kms. 2) That depends on the Clutch adjustment & its Free-Play. An Ideal practice is 'Release Clutch in such a way that the Passengers sitting Inside the car can't feel/notice that change or Gear Shift change. 3) Yes, usually AC & Hydraulic Power Steering units usually pose Unwanted strain to the Engine, especially in Small displacement engines. dr_nishu2010-10-12 20:01:23 Link to comment Share on other sites More sharing options...
goenkakushal Posted October 14, 2010 Report Share Posted October 14, 2010 ABS incleases/decreases straight line breaking on a normal day?? Link to comment Share on other sites More sharing options...
Alok Mathur Posted October 14, 2010 Report Share Posted October 14, 2010 increase Link to comment Share on other sites More sharing options...
abhpom4u Posted October 14, 2010 Report Share Posted October 14, 2010 What does the term "Collapsible Steering" mean? Does the Steering Wheel collapse in the Dash after an accident or anything like that? Link to comment Share on other sites More sharing options...
sgiitk Posted October 14, 2010 Report Share Posted October 14, 2010 It basically goes in, the most common trick is a compressible accordion shaped hollow section. The idea is that if hits the chest of the driver it does not cause major injury. Earlier columns even 'harpooned' the driver. Link to comment Share on other sites More sharing options...
abhpom4u Posted October 14, 2010 Report Share Posted October 14, 2010 It basically goes in' date=' the most common trick is a compressible accordion shaped hollow section. The idea is that if hits the chest of the driver it does not cause major injury. Earlier columns even 'harpooned' the driver.[/quote'] Does this mean that there is a bellow like thing which acts as a spring on an impact? And in this process does the dashboard break due to the steering wheel going in? Link to comment Share on other sites More sharing options...
dr_nishu Posted October 14, 2010 Report Share Posted October 14, 2010 What does the term "Collapsible Steering" mean? Does the Steering Wheel collapse in the Dash after an accident or anything like that? Below is the diagramatic represantation of Collapsing process of the Collasible Steering coloum. Link to comment Share on other sites More sharing options...
abhpom4u Posted October 14, 2010 Report Share Posted October 14, 2010 Below is the diagramatic represantation of Collapsing process of the Collasible Steering coloum. Great diagrammatic explanation buddy Couldn't have had anything better. Link to comment Share on other sites More sharing options...
sgiitk Posted October 15, 2010 Report Share Posted October 15, 2010 Nishu has the other design of articulated (break off links) segments in the excellent illustration he has posted. @abhpom4u the bellows (more common on cheaper cars) are nor designed to spring back. They just collapse. Link to comment Share on other sites More sharing options...
sb-alto Posted November 9, 2010 Report Share Posted November 9, 2010 Have a few questions. 1. Does opening one wheel by self(using wrench) corrupt the alignment of the tyres? 2. What is the life of general coolant and gear oil ? 3. Do cat con require any service within the life of a car? Link to comment Share on other sites More sharing options...
asethi919 Posted November 10, 2010 Report Share Posted November 10, 2010 How much difference does the fact that the SX4 and i20 AT versions only have 4 gears make? Would it be a liability with quite a bit of the driving being highway driving(about 40%)? asethi9192010-11-10 15:48:05 Link to comment Share on other sites More sharing options...
Alok Mathur Posted November 11, 2010 Report Share Posted November 11, 2010 2. What is the life of general coolant and gear oil ? In general it is 20k or one year whichever is earlier but better to refer Owner's Manual (may be odo coverage is increased there). Link to comment Share on other sites More sharing options...
Archived
