srini_38in2001
Octane booster for superbikes
Hi Ref to octane booster best thing is to buy a good quality of TOLUENE add upto 20-25% of volume . need more info you can search on     toluene as octane booster on web got tonnes of info ,
Hi Ref to octane booster best thing is to buy a good quality of TOLUENE add upto 20-25% of volume . need more info you can search on     toluene as octane booster on web got tonnes of info ' date='[/quote']              Toluene is 114 octane   the mix ratio goes like this Example- For total of 20 litres of fuel 10 lit of 91octne+10 lit of Toluene (114 octane)
10x91+10x114/ 20=102.5 octane,
max limit is 30% of toluene can be mixed and to be mixed well
It has more power, run the lowest octane possible without detonation. Low resistance to detonation octane fuel, which is basically the fuel "explosive" inside the cylinder and does not burn quickly and smoothly. Thus, the high-octane fuels, are usually more difficult to burn, especially at low engine compressor.
Remember also that when an octane booster says he will raise the octane level of 10 points, a "point" is typically 0.1 octane. Remember to read the bottle carefully.
