A 1966 LHD Original Chevrolet Impala
anjan_c2007
This is a 1966 model LHD Chevrolet Impala now with my friend who is a
garage owner here at Nagpur with a Mumbai registration.The car "Impala"
is named by GM after the southern African antelope with this name.
This car has the straight six original petrol engine.The dash is fully
original. The seat fabric is original.The door trims too are original.
Lastly, the paint is fully original since 43 years! No doubt the car
has some corrosion in its bodywork.The mechanical work is being done at
the workshop to restart the engine.
255064d1262437474-1966-lhd-original-chev
255065d1262437474-1966-lhd-original-chev
255066d1262437474-1966-lhd-original-chev
255068d1262437474-1966-lhd-original-chev
255069d1262437474-1966-lhd-original-chev
255070d1262437474-1966-lhd-original-chev
255071d1262437474-1966-lhd-original-chev
255072d1262437474-1966-lhd-original-chev
255075d1262437941-1966-lhd-original-chev
255076d1262437941-1966-lhd-original-chev
255082d1262437941-1966-lhd-original-chev
255090d1262438100-1966-lhd-original-chev
255083d1262437941-1966-lhd-original-chev
255080d1262437941-1966-lhd-original-chev
255079d1262437941-1966-lhd-original-chev
255077d1262437941-1966-lhd-original-chev
Notice the Impala logo on the steering console (horn button) and on this picture above.
Link to comment
Thanks sarabjeet and designersf.I am not aware about the cost paid but will post it soon.
Meanwhile some technical details for information about the six cyl 1966 Impala:
Pictures from the oldride website of perfect examples
255182d1262448137-1966-lhd-original-chev
255183d1262448137-1966-lhd-original-chev
255184d1262448137-1966-lhd-original-chev
Chassis Data
Model / Wheelbase / Overall Length/ Width / Front / Rear Treads/Tires
Chevrolet / 119 in 213.2 in / 79.6 in / 61.5 in/ 62.4in / 7.35 x
14/8.55X14
More information about the straight six 1966 Impala from the hemmings website:
The buyer of a new 1965 Impala had a choice of 10 engines including the standard 230-cu.in., 140hp straight-six.
By 1966 the choice narrowed down to seven engine options. The beauty of
the Impala was that Grandma could order an economy car with a straight
six-cylinder engine and three-speed manual transmission or Powerglide;
and those looking for performance could order one of two big-block
V-8s, a 396- or 409-cu.in. engine, even in a four-door Biscayne, the
lowest-priced of the full-size Chevrolets, and have it bolted to a
four-speed transmission. The VIN tag that is riveted to the driver's
side door post will tell you what model the car was originally. For
example, if the first five numbers are "16867," you will know that it
is a true 1966 Impala SS convertible. There is also a cowl tag below
the windshield on the driver's side, which states where the car was
built and gives the paint code and trim. Brent Barrett, a technical
advisor on 1966 full-sized Chevrolets for the National Impala
Association, says some factories, like St. Louis, included a list of
options on the cowl tag, while other factories did not.
The
cylinder heads themselves are strong iron pieces that rarely ever see
head gaskets fail, unless the engine has been severely overheated. The
engines were well designed, but given the state of technology at the
time, including lubrication qualities and out-of-tune carburettors,
many engines need a rebuild after 100,000 miles.
The standard braking system on 1965 and 1966 Impalas was a
four-wheel-hydraulic 11-inch drum setup, front and rear. The total
swept braking area was 328.3 inches. While certainly not
state-of-the-art at the time, the brake system was adequate, and if
properly maintained, rarely failed. The standard 14-inch wheels were
pressed steel with drop-center rims and were fitted with 8.25 x 14-inch
bias-ply tires.
Like all big Chevys of the 1960s, the Impala utilized an independent
front suspension that featured unequal-length A-arms with ball joints,
direct-acting shocks inside heavy-duty coil springs, and a stabilizer
bar. Due to their size and weight, Impalas are known for wearing out
lower ball joints, even with regular lubrication. The original ball
joints were riveted on at the factory, so if you find a car with
bolt-in type, they've been replaced. The upper ball joints, however,
last nearly forever.
The rear suspension is stout and has a rigid axle, coil springs,
direct-acting shocks and a lateral control bar. The bodies on 1965 and
1966 Impalas were rugged, but as with most 1960s cars, they are prone
to rust. Steve Leuing, the National Impala Association and Vintage
Chevrolet Club of America's technical advisor for 1965 full-size
Chevrolets, says the biggest area of concern is body and frame rust.
"Unfortunately, because of the nature of the construction of these
cars, they are very prone to rusting in front, above and behind the
rear-wheel opening, wheel wells, floors, trunk pan and gutters at the
base of the windshield," Steve says. Convertibles are susceptible to
severe rust in the front and rear floor pan because water doesn't get
channeled out properly. However, one area of these cars, the rocker
panels, remains solid unless exposed repeatedly to salt-covered roads.
This is due to "flush and dry" rocker panels, which were designed to
allow water to flow through, followed by a burst of air to dry out the
remaining moisture. The door hinges were built like Fort Knox, but
after 40 years, the bushings may need replacing.
Link to comment
Again took the car's pictures with the OE wheel caps on. I lifted these
wheel caps (with real spokes affixed on the wheel cap rim) and believe
me- each one weighs maybe as much as a Maruti 800 rim (without the
tyre/tube)! The original chrome is quite intact here with some little
signs of rusting only in a few places.
261924d1263127127-1966-lhd-original-chev
261925d1263127127-1966-lhd-original-chev
261926d1263127127-1966-lhd-original-chev
Link to comment
  • 2 weeks later...
designersf the owner was negotiating with someone in Kolkata who may buy it perhaps. The 6 cyl engine has fired up now. Indeed, I was often seeing the gigantic Rochester carburettor being readied for the engine firing D day.
Also saw the RC/TC book. The car is an import and came to Mumbai in 1967. It was imported by an industrialist. Thereafter in the 1970's it was sold to the business family of the sister of Mr Prafulla Patel, Union Minister. This family resides in Chandrapur.It was garaged by them maybe a decade back and was kept as original.
That explains the mystery (was asked this question by many as it has a Bombay registration) as to why it was not dieselised or why it did not land up with Bombay film wallahs to end up being bashed up or burnt in some movie? It was 1200 kms away from Bombay and in safe custody.
anjan_c20072010-01-25 10:59:18
Link to comment
  • 1 year later...
Archived
