Autoliebhaber
Tyre problem
If the Tyre Tread depth is less than 4mm or are more than 4 years Old, then Replace them, don't matters how they looks, etc.
Also Driving Style, Road Conditions, Type of vehicle, Season of the Area in which you are living/driving, etc are other factors which also makes the difference in the longeivity of the Tyres of your vehicle.
i used to have a similar issue..get the insides of the tire thoroughly checked. In my case, one of the steel wires that make the belt had started to protude. JK promptly changed all the 5 tires.
P.s. I was running a special set of softer compound JK Ultimas. :P
