TheBull
Auto Transmission - LPG/CNG combo!
Yes i had converted my corolla AT into CNG , i had an electronic kit so impact on packup was negligible. If you are converting a less powered AT car into CNG u should have a electronic kit if it is MFI or a Booster.
Had done 60,000km on the corolla with CNG and it didn't give any touble. Be sure to top-up engine oil in every 4000 - 5000 km with CNG engine oils.
As for FE is concerned with a fill-up of Rs 210 i use to go 115-120 km with A/C all time in Mumbai traffic.
Next will be a Civic or Maybe a New altis CNG
sarabjeet2010-05-24 10:30:13
Thanks for response. I am planning to convert i10 AT to CNG, any suggestions?
it is Kappa engine right ? it should be no problem go for electronic kit and if u feel lack in power which i don't think should be an issue , then opt for a booster.
is your car in warrenty period ?
it is Kappa engine right ? it should be no problem go for electronic kit and if u feel lack in power which i don't think should be an issue ' date=' then opt for a booster.
[/quote'] It is just one month old :)
Hi Guys
I am new to Auto car.
I own a Maruti Esteem VXi model. a few days back i fitted it with CNG, the car was running fine in the initial but now it has started giving problems.
the car has started getting heat up if u run it on A/C and the A/C also trips. My average running for the day is 120 kms, there is no problem with the pick up or so and it smoothly touches 140k.
I any one has any suggestion or are facing the same kind of problem, please advise.
Thanks in advance.
Hi Guys
I own a Maruti Esteem VXi model. a few days back i fitted it with CNG' date=' the car was running fine in the initial but now it has started giving problems.
Thanks in advance.
check your radiator coolent , and your engine oil , change to CNG engine oils they keep the engine cool. Esteems are most successful on CNG
