sb-alto
Maruti to launch Ritz, Estilo and WagonR CNG
Maruti Suzuki Ritz, Estilo to get CNG versions
Maruti Suzuki India would be launching CNG versions
of the Ritz and the Estilo in the coming months, reports Goa on Wheels.
Till now the only passenger vehicle with CNG technology Maruti has
produced is the Alto.
Maruti intends to boost its share in the CNG vehicle segment which is
likely to grow rapidly with the increase in fuel prices recently.
The Maruti Ritz has been selling well and the CNG version would further
strengthen its market share. As far as the Estilo is concerned, a CNG
version wouldn
Hi Guys,
The dual ECU for Petrol/CNG: Did it mean a flex fuel ECU or seperate ECusfor Petrol and CNG like in case of retrofits?
Think iGPI engines come with separate injectors for all the cylinders. Does it mean that CNG injectors will be placed on the crank case itself similar to Petrol Injectors? Or are they using the same injector to inject both CNg and Petrol? smiley5.gif Any Idea guys?
From, the Company Release spec, it seems that these are having Seprate ECU for both Fuel Systems.
& IMO, CNG Injectors would have to be the Seprate ones from the Petrol ones & are fitted in the Cylinder Head(just like as in the Chevrolet Aveo) & it's the top-most part of the Engine, not to the Crankcase, which is the Bottom-most part of the engine just above the Oil-Sump.
