lineshshah
Replacement of Apache's suspension with fz 150
I have Apache 150 (2005) 12k kms,
it is a superb bike but front suspension is very bad! need replacement and i found Yamaha fz's front suspension is much stronger then any bikes so i am planing to replace it with my apache's older one!!~!
is this mod. possible ?
friends please give me your feedback
lineshshah2010-07-02 15:49:46
Fz's forks are much Robust & larger in Size(in length & diameter) than Apache's, So Entire Steering Unit/Parts has to be changed, all leading to the Altered characterstics of the Bike, which may also go to the Opposite way as per you desired.
Try to Replace them with that of the new Apache RTR 160 or 180's, this is a much easier & almost Failure-Proof job.
I have Apache 150 (2005) 12k kms' date='
Yes the fronts shocks do give problems , mine is also troubling me , go for the apache shocks only don't spoil the superb handling
