prasanth.mdu 0 Report post Posted February 1, 2008 Iam planning to buy Mahindra LOGAN. The only problem for LOGAN is absence of ABS in higher end model also. After buying LOGAN, can i fit ABS in Tamil Nadu? Any approximate charges? Quote Share this post Link to post Share on other sites
rssh 59 Report post Posted February 1, 2008 Forget it after market ABS are more dangerous than the factory fitted .Also wait for Dezire to come in March and you will get ABS in top end model. Quote Share this post Link to post Share on other sites
mndvishnu 0 Report post Posted February 2, 2008 No dude , aftermarket ABS fitment isnt good and not recomnded too , incase you want an ABS , go for the Verna VGT ABS or else Swift VDI ABS or the Fabia Diesel Ambiente Cheers!!! Quote Share this post Link to post Share on other sites
FuelRunGod 200 Report post Posted February 2, 2008 I echo the other members, would advise against aftermarket fitment. FRG Quote Share this post Link to post Share on other sites
gego&bones 0 Report post Posted October 10, 2010 Hi guys, I have a Swift Dzire Ldi, which is a year old. Can i install ABS system for the brakes. Any idea how much will it costs? Has anyone done so far? Quote Share this post Link to post Share on other sites
BonFre 0 Report post Posted October 10, 2010 Well, its do-able but not recommended. ABS should come as a factory fitment only. Quote Share this post Link to post Share on other sites
sgiitk 0 Report post Posted October 11, 2010 Title changed - more generic, threads merged. MOD Quote Share this post Link to post Share on other sites
NAREN64 0 Report post Posted October 11, 2010 Well' date=' its do-able but not recommended. ABS should come as a factory fitment only.[/quote'] Why ? May be the reason the hydraulic break hoses supplied with cars fitted with ABS are stronger than the cars without ABS. Please confirm. Also if ABS is fitted than the next question comes is will EBD be available. Quote Share this post Link to post Share on other sites
BonFre 0 Report post Posted October 11, 2010 For ABS, ECU & Speed sensors, Pump, Valves, etc. have to be installed. These fitments are out of the scope of usual workshops. Neither do they have the equipment nor the testing facility. Factory fitment is the best or else there has to be a specialized ABS/Brake clinic. Quote Share this post Link to post Share on other sites
Durango Dude 2 Report post Posted October 12, 2010 May be just, if Osamu Suzuki or R C Bhargava are related to you, otherwise make a wise decision next time you go in for a car buy one with all the safety features; God knows when you may need it. Quote Share this post Link to post Share on other sites
NAREN64 0 Report post Posted October 12, 2010 May be just' date=' if Osamu Suzuki or R C Bhargava are related to you, otherwise make a wise decision next time you go in for a car buy one with all the safety features; God knows when you may need it. [/quote'] Yes sir, It would have been a previlage to have such relations. My Linea is with ABS, just wanted to check if it is possible. I made a wise decision while buying the Linea. Quote Share this post Link to post Share on other sites
carispassion 0 Report post Posted October 12, 2010 Hey guys, I am still wondering about why it shouldn't be possible. If we are replacing all the parts from MASS itself, why should it be unsafe? MASS claims that they are experts in servicing every Maruti car be it fitted with ABS, Airbag or what so ever. So I think if he could change all the parts corresponding to the ABS equipped model, think it should be possible. It includes, the full wiring harness, the Hydraulic unit of ABS, wheel speed sensors, the fluid lines etc. May be one could check the Spare-parts manual for which all parts are unique for the ABS equipped model. However, expect a cost around 50k, though the ABS fitted car will be ask for a premium of just 20k. Quote Share this post Link to post Share on other sites
rameshbabu.n 6 Report post Posted October 12, 2010 ... why it shouldn't be possible.... why should it be unsafe? MASS claims that they are experts in servicing every Maruti car be it fitted with ABS' date=' Airbag or what so ever.[/quote'] Technically, it is possible. The only worry is - will it work when it matters most ? By seeing the quality of so-called `technical experts' the MASSs have, I have my own doubts whether they can first list out all those parts that are needed to be replaced and a separate list of those parts which are to be added. I am sure no MASS will pass this simple test. It's better to live with the existing car. Or, if desparate to have ABS, buy a new car with ABS. For your sake and safety, do not depend upon the half baked knowledge or (near nil) experience of those so-called `technical experts' in MASSs in undertaking such complex jobs. Quote Share this post Link to post Share on other sites
reddy 12 Report post Posted October 12, 2010 I dont think we have a choice , we need to buy all sensors incorporate into car and ECU programming had to be done to cordinate all the sensors ,which is out of perview of dealer ,best is to buy one with ABS Quote Share this post Link to post Share on other sites
dr_nishu 198 Report post Posted October 14, 2010 I have a Swift Dzire Ldi' date=' which is a year old. Can i install ABS system for the brakes. Any idea how much will it costs? Has anyone done so far? [/quote'] Its not advisable to fit such kinds of Genuine Safety features Aftermarket. Prime reasons being; -Safety remains the 1st reason, as chances of Errors creeping in increases in such cases during their Installation, hence doubting their Reliability. -Cost involved in such changes will go much more than the company offering it as OE, as it's the Part/Mechanism which have to be Installed during the Manufacturing process. -Being an Electronic feature, its Calibration for the perfect/appropriate results isn't possible to the Max, Outside the AfSS or Manufacturing plant. Quote Share this post Link to post Share on other sites
