Pranab*
Laura TDI 1.9 Engine oil
My laura is showing low oil signal, checked it and its quite low. Which oil should i use ?
Purchased the car in jan 2010, never had a single problem till now... anyway which oil should i purchase ?
It is normal for the engine to consume oil. The oil consumption may be
as much as 0.5 Lit/1000 km depending on your style of driving and the
conditions under which you operate your vehicle. The oil consumption may
be slightly higher than this during the first 5000 kilometers. One
should therefore check the oil level at regular intervals, preferably
every time after the fuel tank is filled or after driving for long
stretches.
DIESEL ENGINES (without DPF)
Model
Plat-form
Engine Type
Engine Code
VW Approval Oil (Specification)
Service Interval
New Superb
B6
2.0 TDI PD
BKD
VW 505 01
15000 Km
2.0 TDI CR
CLJA
VW 507 00
15000 Km
Superb
B5
2.5 TDI
BDG
VW 505 01
15000 Km
New Laura
A5
2.0 TDI PD
BKD
VW 505 01
15000 Km
2.0 TDI CR
CLCB
VW 507 00
15000 Km
2.0 TDI CR
CLCA
VW 507 00
15000 Km
Laura
A5
1.9 TDI PD
BJB, BXE, BKC
VW 505 01
15000 Km
Fabia
A05
1.4 TDI PD
BNM
VW 505 01
15000 Km
Durango Dude2010-11-13 11:39:35
If it is a case of just topping up then go to Skoda Service and top it up. Mixing different grade oils is not good.
If going for new oil, then Mobil, Motul, and Valvoline has dedicated diesel synthetic oils. Check the website for the correct grade as recommended.
